No problem, we all have ‘other projects’ that infringe on our pattern making time ![]()
Yes, that’s correct. The idea is to get used to using references inside of the pattern (this makes the pattern resize smoothly when the measurements file is changed) and to keep the 180° angle on either side of a point - often these will be at 90° to something else, but this isn’t a hard & fast rule in this type of curve, so you can adjust them in small increments until you get the desired curve.
I found it much easier to be able to edit the points rather than to have to open the Properties of a curve each time I wanted to make a minor adjustment.
Yip! first you lay the game board & then you play the game. If you wish, you can delete the curve (you can always Undo the delete, or download the test file again) on the file that I sent you & see the points that I lay down before creating the curve.
The method is described in this topic, which could help you a lot to decide on the length & angle of you curve control points, won’t really work in your case, however, this can be solved if you don’t expect to change the size of the pattern.
I’ve added a new curve to this test file which you can have a look at:
Curve Example - B.sm2d (6.9 KB)
