A problem
Hi Pilar!
It looks like you are using an old version. Valentina has changed, please install the latest version. Download & install Valentina v0.4.0 from here http://valentinaproject.bitbucket.org/index.html#current_release.
Valentina doesn’t have a Microsoft or Mac certificate yet. If you see a certificate message during install, click through it to continue installation. If you use Linux, then there’s no certificate message.
To learn how to use Valentina, watch these videos on our YouTube Channel https://www.youtube.com/channel/UC61WgbNdZ_wqxKf9PzJrjgA
  1. Configuration https://www.youtube.com/watch?v=mrOKbK2nxKE&list=PLaxePMnFUf3bA8M4PPdylMyoQzDuwYOni
  2. Measurements https://www.youtube.com/watch?v=X_sFRvnc-zg&list=PLaxePMnFUf3Ylxr7UizPgkSexfljH-_ho
  3. Simple Pattern - Square https://www.youtube.com/channel/UC61WgbNdZ_wqxKf9PzJrjgA/playlists?shelf_id=3&sort=dd&view=50
  4. Simple Pattern - Bodice https://www.youtube.com/channel/UC61WgbNdZ_wqxKf9PzJrjgA/playlists?shelf_id=4&view=50&sort=dd
Hope this helps. Please continue let us know whenever you encounter a problem or have a question.
Best, SusanOn Thu, Jan 28, 2016 at 6:32 AM, Pilar Acon Segura wrote:
Hello again!
I found my first problem…
I dont get the option of *use a base pattern *that you can see in the file I attached to this mail. What can I do? Need to start from an standard pattern!
If you want, once I learn how to use the software, I can record a few videotutorials in spanish in compensation for your help!
Thanks a lot,
Pilar
