Hi @sjoerdg
Wow! You’re doing great
I’m battling the war of putting pleats into a blouse that will also serve as darts. For something that sounds so simple, my pea-brain is really battling
Hi @sjoerdg
Good evening Mr Soerj. When I want to use your pattern an error message appears, a copy of which appears. What should I do ? . Note that I use Valentina software. Yours truly. Erreur draw.docx (23,8 Ko)
If the pattern was saved in Seamly2D with a version greater than 0.6.3, it will no longer work in Valentina (and vice versa). I suggest try using Seamly2D.
Bonjours Thanks a lot
I followed your valuable advice to the letter. But Seamly does not have access to my “Desktop” then “Taking measurements” where the ZPattern file is located. What should I do. Thank you for your understanding. Please find attached a screenshot. Thank you for your understanding. Seamly echec.docx (119,1 Ko)
Try clicking on My Computer and then Desktop on the left section of the screenshot that you sent.
Still nothing really sorry. Seamly echec 2.docx (111,9 Ko)
You have to setup the file paths in the Application Preferences->Paths. I’d attach a screencap, but I dont have internet access with my laptop at the moment.
Bonjours, J’ai suivi vos précieux conseils et comme par magie ça fonctionne. Merci beaucoup Hello, I followed your valuable advice and like magic it works. Thank you so much
