Creation of a 'New' Multi-size-table
In the normal process of pattern production a pattern will be drafted or draped, and then “graded” rather than drafting / draping each size to fill in the range of the patten sizes. The initial pattern is the base size. For example I would generally make a pattern for a mens jacket in size 40R… make a sample adjusting the pattern as needed. Once the pattern is OK, I could then grade down to a 34, 36 & 38, and grade up to a 42, 44, 46, and 48. If needed the length could aslo be graded to account for Short, Log and XLong. You generally want the base size / height somewhere in the middle as you introduce less error grading from a 40R to a 48XL than you would a 34S to 48XL.
The multisize in Seamly is more or less a grading process. With a caveat as currently implemented… it’s metric only, and base height is more related to the Russian Mens GOST table than it would be to say something like mens Short, Regular, Long, Extra Long. The orginal dev was Ukranian and thus the reason for the hard coded sizes and heights in metric.
BTW… you may find this interesting, where I took an existing pattern of a mens jacket, drafted the grade points into Seamly, and then using a standard set of grade rules incorporated into the formulas, am able to apply a set of measurements to draft a made to measure pattern. The grade rules being how much a grade point moves in/out and up/dn for each increment in size. The base size was a 38R.
