Critical Error, Exception: Element Groups is not allowedd
I think… and hoping that this was related to the (fixed) issue(s) we were having awhile back with the extra LF’s and disapearing measurement files. :crossed_fingers:
Yes, it’s very confusing, everytime it pops up. With the wonderful work that you’re doing on the software, I just can’t express enough how important it is to do the weekly updates every week.
@a_g_26
Just an update… @Grace was correct on the ME file with the missing date… I was looking for the file “measurements.smis”, but since I already had 7 other “measurements.smis” files it got renamed to “measurements(8).smis”, :roll_eyes:
@Grace
I may look at the schema for the ME files. I think currently some of the “personal” data is required to be a valid file per the schema. That’s why it was throwing the error for the missing date. I think we can change that so the personal data is not required as per the schema.
Yes, I totally agree with you. Not many people use this personal data, so it should be blank until it’s used. :hugs:
Hi @Grace I’m having the same issue. I downloaded the app just two weeks ago, and I’m still experiencing this error.
Thk U for your support I fixed as you mentiones
Hi @anaperdomohn
The newer app will not fix older patterns with the error. The newer releases won’t write a broken file, but they can’t fix a broken one either. This has to be done manually by editing the xml files & switching the order of any <images> and <groups> blocks. the <groups> have to appear first as that is the order the <groups. appear in the schema that is used to validate the xml pattern files.
If you want - you can post any broken patterns and we can fix them for you.
Since it still seems to be an ongoing issue I should probably write a fix that auto repairs broken files. :thinking:
To verify, are you saying that you first installed Seamly two weeks ago, or that you are using a version from just a couple weeks back?
I would assume a version from 2 weeks ago. It’s been over a year since we fixed the images & groups issue.
Hi @Douglas
I actually just installed the latest version of Seamly2D recently, and I’m new to using the application. So, these are not older patterns that were created with a previous version of the app. I created these patterns last week using the current version.
I was able to fix the files by following Grace’s instructions and editing with a text editor.
Are you sure it was the latest version used to create the pattern files? The newer releases implicitly write the <groups> and <images> tags in the correct order. The release (or 2) where there was a issue was not writing these 2 tags when a new block was added. When we only had Groups there was no issue. When we added the Image Import the issue popped up as the <images> tag could be written first… then at some point the <groups>… causing the error.
Yes… it’s pretty simple fix.
Hi @Douglas , I think there is a pending update available now, but the version I have been using since I installed Seamly2D is 2026.8.31.143 for Windows, see de image below:
