Feed error
Hi @Ashtag, Welcome to Seamly! You鈥檒l see at the top of the forum here a link to Download latest, which links to a post with download links to all the latest releases. Or you could check Releases 路 FashionFreedom/Seamly2D 路 GitHub if you prefer a more gritty computing experience.
As for the error, If you would post which OS & Seamly release date you鈥檙e using, one of the devs will be around in a bit to see about figuring out the problem.
Happy drafting!
