Hello & welcome, @nightshiftKnitter (from South Africa middle of nowhere). ![]()
This topic can serve as a basic instruction on the slash & spread. The software has improved since it was written & I was just learning the software, myself (and patternmaking). Since that time, I can assure you that, if you can do it on paper, then you can do it in Seamly - slash & spread, move & rotate, mirrorā¦
Ok, so I havenāt even heard of Suzie Furrer, so I donāt know anything about her methods, but if theyāre similar to HJA, then Iād suggest that you create your basic drafts (moulage) using a multisize measurement chart, anyway. This way you can test that your curves, arcs and lines meet over a very wide range of sizes, even if those sizes donāt increment properly, but rather generally. Once your pattern is created, then you can load in your personal measurements (very carefully taken) and sew up a text moulage and check the fit before making any adjustments to the draft.
Gina Renee Designs has written an amazing book on fitting problems that one can buy and also has a few small (free) ebooks on the subject in her tutorials section. And yes, Seamly can handle these kinds of adjustments.
Yes, yes, yes!!! This is totally magic of using Seamly. You donāt even need to duplicate the file, just go Menu > Measurements > Load Individual > Select the measurement file and everything should just readjust/resize - like magic before your eyes - and youāre ready to start cutting with your new projector ![]()
Normally, I keep my basic pattern intact as a master pattern. This I duplicate by Saving As ??? and then start changing and adding to create the design required (this way, I donāt have to create the master pattern from scratch each time).
Yes, it can. You will just need to structure it very carefully⦠If A>B, then T, otherwise if A>C, then U (and you can carry on for quite a while like this), otherwise Z. However, you canāt use actual line lengths or curves in the Variables, so Iād suggest that you use the Measurement File codes to get the formulas to resize according to measurements.
