How to put passmark onto a curve for a sleeve
a further question. Can you successfully add a passmark on the curve after the detail piece has been created? I cannot seem to do so. go back and add a point on a curve in draw mode, create a node in add details. Adding it to the main path as a passmark results in a distorted curve, either before or after the passmark depending on where the node is placed on the main path list.
Is the solution to delete the piece and then recreate it including the newly placed point on the curve?
For future reference, is it ok to add on to a question that is a bit older such as this? or start a new topic?
