I already addressed that… an object will only be able to added to 1 group at a time. Otherwise with all the permutations that can result with adding an object to different groups does get weird - and unpredictable as to it’s visibility. That “other” program who’s name shall not be said, has this problem. Again, the groups tool acts more like a layer than it does grouping objects in a vector program, where groups can be nested. Even then in a program like Corel Draw, you can’t group objects across groups, because when you click on an object it selects it’s whole group… which could then be nested. You can’t nest layers.
1 Líbí se
