Internal Path - how do I create one
How do I create an internal path or make one available to the seam allowance tool ?
@bamba, as I understand, you can create an internal path by using the piece path tool under the Detail tab (v. 0.5.0). The resulting path appears in the Internal Paths section of Options for the corresponding pattern piece. I do not know how to make it available to the seam allowance tool.
When you create an internal path you select type. There are two types: internal path and custom seam allowance.
Thank you! I found this thread on new seam alowances: http://forum.valentina-project.org/t/redesign-seam-allowance-tool/686/9 Looks like you have already explained the whole process.
That’s the reason why i think the Wiki is better place for the User Manual. It is to easy to lose information here.
