Intersection Arc/Curve & Line
Here I created a line from A to A1 with a length of 5cm.
Then I created an arc (using the arc tool) with a diameter of 5cm starting at the A1 node and going to 90°.
Then I placed a point A2 (using the Segment an Arc tool) 4cm away from A1 on along the arc.
Is this what you are trying to do?
