Intersection Arc/Curve & Line
Here’s the solution I came up with, it’s kinda messy, but I think it works:
  • To put forward point
  1. draw a line from the center of the arc to the point on the arc
  2. make an arc of the specified length, (bottom right icon in Grace’s picture,) having the same radius as the arc you want to put points on. ETA: with its starting angle being that of the line drawn in the previous step
  3. segment the arc of the specified length by its own length
  • For the back point
  1. Mirror Objects by Line (ML), in the Operations toolbox
  2. select the forward point, press enter
  3. select the line going from the center of the arc to the center point
  • Profit!
I hope that makes sense!
1 polubienie
