Multisize Table With Variable "In Sizes"
Hello and welcome to the Seamly2D forum, @fidelhviegas
Currently, SeamlyME doesn’t support this, although you can create 2 separate measurement files for the different sections which may be easily uploaded into the pattern, as needed.
It is in the pipline as you will see from this discussion.
Yes, you can export the pattern in each size and nest them in Illustrator or Inkscape.
