New feature Curve tool Overlay - "French" curve
Ich arbeite mit der Bezierkurve.
Eine Sache ist jedoch sehr umstädlich: Ich erstelle immer eine Gruppe in der ich Kurven und Nähte kontrolliere. Leider kann man eine Bezierkurve nur sehr umständlich korrigieren.
Wenn man die Möglichkeit hätte nachträglich Punkte auf eine Kurve zu setzen die Hebel haben. Dann könnte man der Kurve besser eine unterschiedliche Richtung geben.
Man muss sich nicht im Vorfeld überlegen wo man die Punkte plaziert. Bei der Bezierpunkte gibt es auch nur zwei Punkte. Es ist auch schwierig die in alle vier Richtungen zu bewegen.
Where does this stand almost 2 years later? And also the thread on a user feature request that would let a user to specify the length of a spline in order to create the desired curve,
Adobe has had a french curve tool out there that lets users of Illustrator (and I think Photoshop) bring in their tool into the design workspace, rotate it around until it hits the two points, and then create the spline curve connecting the two points. Despite being not being commercial and relying on volunteers, this has been done before.
The Kolson method is called out as a way for creating bezier curves but one has to figure out angles as well as lengths.
So have these user requests been forgotten, put on the back burner, formally planned in the development road map, or internally decided against implementing?
Hi @DaBose! Yep we still want this… Feature: "French curve" tool · Issue #187 · FashionFreedom/Seamly2D · GitHub Know anyone who wants to implement it?
Huh? Since when did Adobe Illustrator become “non” commercial and relying on volunteers? It’s one thing to program a “french curve” tool in a drawing program, quite another to do it in a pattern making program with a parametric paradigm. If it’s that easy please volunteer and help program it for us. :wink:
