Preferences discussion
Ok… that makes sense… although maybe it seems that should be a PDF / SVG export option?
No it would just be to “force” a first time user to configure certain settings to get them going.
Could also add am option to show an intro video to get started. To be honest, I was a bit baffled until I watched the video on doing the panty pattern… and went Ok, now it makes sense. :slight_smile:
They are 2 separtate files… stored in AppData/Roaming/Seamly2DTeam/Seamly2D.ini and SeamlyMe.ini.
Agreed… but again there are 2 separate preference files. ???
Here’s the reason for the difference from the Qt manual on Locale… based on how the label languages are gathered:
Returns the dash-separated language, script and country (and possibly other BCP47 fields) of this locale as a string.
Unlike the uiLanguages() the returned value of the bcp47Name() represents the locale name of the QLocale data but not the language the user-interface should be in.
This function tries to conform the locale name to BCP47.
The GUI languages are actually the ones that translation files were prepared for,
Could do that… I have several programs that providing loading like the last five files used For ex:
stuio
L’idée d’ajouter des préférences qui peuvent être configurées sur un écran de démarrage ne vise pas à remplacer les préférences normales. Ce serait de configurer les paramètres de base tels que les unités de langue et de modèle la première fois que l’application est utilisée pour démarrer sans avoir à rechercher comment les définir.
