Hello
It’s terrible I can not print properly and I can not reinstall the old version because my bosses have been done recently.
I am trying to create a pdf but Seamly 2 D be created as a sheet A 4 and I do not know how to change that.
The configuration is well roll 24p but when I create the pdf there is only A4 or letter or else but not A1
I am stuck and I have no solution.
Can I urgently ask you to send me a .pdf roll A1
J’ai exporté le motif sous forme de fichier .svg que vous pouvez ouvrir dans un éditeur différent, comme Inkscape, et essayez de l’imprimer à partir du papier de format correct.
Hello !
It is almost the outcome of the story !!
After a morning with the after sales service of my printer, we found a setting that allows me to print.
I still have not figured out the end of the story, but it seems that an update of the printer software has seamly confused and the communication between the 2 on the margins and the cutter.
The technician did not even understand where the problem came from, he seems to want to look again to improve the system …
No matter, I found my pattern!
Thank you very much for your support and presence !!! I hope this subject will finally be closed !!
