Print patterns softwere
I can not print. I have to install some special software for printing in pdf format. When I ask you to print the mask buttons, they are inactive. If so, could you indicate the link? Thank you
What Valentina version are you are using, and which operating system ( Mac, Windows, or Linux) Does this describe the steps you followed:
  1. Generate a layout
  2. Select File/Layout/Print PDF
  3. The print dialog buttons are disabled
Can you provide screenshots of the dialog box with disabled options?
I am not sure whether this will help you. If you are running the latest version or even the version 0.5.0.0 stable version, it should. Print a pattern in Valentina version 0.6.x.x - #2 by dismine
actually, I sent you the wrong pointer @agoefiloeforbici I should have sent Print a pattern in Valentina version 0.6.x.x
this is the same thread, just scrolled farther up
Thank you. Now it is ok
