Grace
26 Wrzesień 2019 14:38
9
Hi, I’m back from holiday
Unfortunately, I only have a small A4 Epson printer, so my options don’t allow to create a page larger than an A3, so I won’t even be able to try for you.
Here are a few topics that may help to solve your problem:
Français:
Attaché est un tutoriel pour les débutants. Il couvre le workflow de base de la création d’un projet à imprimer au format carrelée et comment créer des points, des lignes, des pièces de détail et coutures aux coutures.
Tutorial_QuiltSquare_Fr.pdf (655.2 KB)
English: Attached is a tutorial for beginners. It covers the basic workflow from creating a draft to printing it out in tiled format and how to create points, lines, detail pieces, and seam allowances.
Tutorial_QuiltSquare.p…
This is what mine looks like without me making any changes.
[image]
[image]
So this has to be pulling from elseware
[image]
I agree with @kmf that it seems that the printer is cutting off the printing because your margins in the pattern are smaller than the margins that your printer presets. So you’ll need to set the margins in the pattern a little wider to keep the pattern within the printers printing area or set the printers margins to print to the edge of the paper. Unfortunately, I only have an A4 paper printer (a little deskjet) so I can’t test on a roll, but here is a part of a tutorial that I set up for some f…
You might need to use a wider layout size. It’s the same sort of idea when laying out pattern pieces to cut… generally the wider the fabric, the less fabric it takes overall. If you select a layout size that’s too narrow, you may only get 1 pattern pieces to fit across the width, so the program places pieces on another layout sheet - thus wasting space.Maybe play around with not allowing certain (larger?) pieces to rotate may help to save space.
If you’re printing a tiled PDF you have to think…
Can someone let me in on the secret to get a single pattern piece that will easily fit on one page to print on a single page.
No matter what settings i change it still tries to cut the piece in half and print on two pages.
Thanks
(sorry if I am abrupt today… in a pissy mood )
Please let me know how you managed or if you haven’t managed and I’ll look into it further.
Thank you
