When I try to open a measurement file done in inches, I get an error that says a pattern can’t be graded in inches and nothing happens. Could you please fix this? I’m 54 and I have no desire to start using metric at this point in my life. Thank you
When a pattern is created, the designer chooses between inches and centimeters. So the measurements need to match.
You don’t understand, I am the designer and I have the program set to inches and I take and create the measurements in inches but when I import the measurement file into V it tells me that patterns can’t be graded in inches.
Actually this is not true. Values can be easely converted to pattern units.
if (qApp->patternUnit() == Unit::Inch && m->Type() == MeasurementsType::Standard)
qWarning()<<"Gradation doesn't support inches.";
return false;
This means when your pattern uses inches and measurements standard you can’t open a pattern. We do not support multi size tables with inches. Use individual measurements instead.
Read more about standard measurements.
