Trying to understand the relationship between block creation order and history
The first one defaults to “A” as the base point, the second defaults to “B”, … the sixth one defaults to “F”. So you might start drafting by making six Draft Blocks & then populating only the ones which you need, hopefully leaving one or two empties to buffer your “Dashboard”.
