Today I logged into the wiki.valentinaproject.org and a phishing probe popped up asking me for username and password ( I had already entered them). Iif you get this popup when logging in just press cancel. I’ve filed a report about this.
Why do you think this is a phishing? Maybe this is a mistake. There is site https://simplicitysolutionsgroup.com/
. And looks like their wiki is hidden behind password.
They said they are looking into it. If you look a the error message it says http:// not https://
It is possible this is a configuration issue at Miraheze that contributed to this, and that it isn’t a phishing scam. In any case, not a good situation. There were other messages when I logged out.
I logged in today, problem is resolved.
I seem to be unable to log in to the wiki. I tried using the same user name and password that I use on the Valentina blog site (which is here, I believe) and I get the error: The supplied credentials could not be authenticated. I tried logging out (here) and back in to make sure I was using the same password and was still unable to log in to the wiki site. I tried this because I wanted to read the new info that @slpencer had posted. The login issue does not prevent me from reading the information, but I assume that it would prevent me from adding to the wiki. Is this related to the login problems you already mentioned?
You should register on the wiki separately.
You can re-use the same username and password that you use on the forum to create a new account on the wiki. The wiki and forum have different service providers.
I did just that after I read what @dismine said. I had not realized they were separate because of the integration of the menu items at the top of the forum. thanks
