Hello everyone
I wonder if is their a way to add more then one label text box on one pattern piece…?
for example name label + selvage which i rotate vertical.
If I write another line of text - it’s in the same label box, so I can not control them separately
There is a way to do this, but you will have to edit the pattern properties under File > Pattern Properties > Label Data.
Fill in the fields here with the required info and create a template for the label:
This will become your cenre pattern (main) label.
Then in the pattern layout options, you can add a 2nd label as you require it with some of your own words that are needed. Create a template for that label:
Then you set separate labels for the 2 labels here:
I’ve done it a bit back-to-front, figuring how it works so I can show you, but this is my result :
You will need to figure out the template a bit, but it can be done
