I did it, I managed to build Seamly on Ubuntu 22. This computer has been through some trials, so I have no hope of recalling what dependencies I might have previously filled, but here’s what I did, though not completely in the same order. There was a lot of, “Now, how do I fix this dependency?”
My first step, after attempting to figure out the starting point on my own, & which this recounting of my travails will hopefully spare the future adventurer, was to try to figure out if the AppImage stopped being available because a make related file got lost. Eventually I managed to get a compare of the 2022-04-11 vs the 2022-10-31 source & scrolled down until I saw something promising: dist/appimage-builder-recipe-test.yml. A short perusal revealed that qmake was to call the file that looked suspiciously like it ought to be the make related file. The various commands of pertinent, & possibly pertinent utility which I subjected my terminal to follows:
sudo apt install qt5-qmake
Then I was missing some sort of qt core, which apt appeared to think I had, but someone online had suggested this package for that error:
sudo apt install qtbase5-dev
Yay, new error! something about XML. Ooh, this one looks promising. Last time I needed the one with “dev” in its name:
sudo apt install libqt5xmlpatterns5-dev
svg now? I wonder what other drawing type packages I’ll need. Oh well, I can’t think what to search for, I guess I’ll do it one at a time…
sudo apt install libqt5svg5-dev
…but this package having something to do with graphics related widgets sounds super apropos, so I’ll just install it before qmake complains I don’t have it this time:
sudo apt install libqtwt-qt5-dev
I also needed to install this one, I think if I’d been paying attention it would have been about now that I discovered my need instead of at the beginning —seriously, a linux distro without a C compiler in the basic install? psh!:
sudo apt install g++
These commands get run in the base folder of the source code:
sudo qmake PREFIX=/usr Seamly2D.pro -r -d CONFIG+=no_ccache CONFIG+=noDebugSymbols && echo
Note that I’m pretty sure the && echo was superfluous, as well as the PREFIX=/usr. I also was unable to complete the build without the CONFIG+=no_ccache, & suspect that -r is essential. I didn’t experiment much. sudo qmake Seamly2D.pro didn’t show missing dependencies, I think it’s the -d which did that. I didn’t feel like messing around any more than I had to to get it working, so I just used the full string after I discovered that.
sudo make -j$(nproc) && echo
Again, I don’t think the && echo did anything for me, but I was done playing around, & it didn’t complain about it being there.
sudo make install
& now I can open SeamlyMe without opening Seamly2D first! It’s not a huge deal, but every once in a while I have wished that I wasn’t using the AppImage. SeamlyMe still opens with the warning: “QFSFileEngine::open: No file name specified” but it still runs, so I guess that’s okay. Oh, & the measurement diagrams still aren’t showing. I may try looking into that sometime, but I have a couple sewing projects that I really ought to prioritize.
Thank you & good night!
