"By second edge right angle" feature not working for seam allowance
Hi All,
My apoligies if this issue has already been discussed/reported. I’m having an issue with seam allowance feature when I use the “By second edge right angle” option on point A2. This feature works properly in valentina latest dev version (0.7.53).
Can a dev please have a look what valentina is doing differently here? I can workaround this bug with using custom seam allowances so it is not the end of the world, but it is a bit finicky.
Seamly file can be found here: seamallowanceissue.sm2d (3.5 KB)
Hello and welcome to the Seamly forum, @krumplib430
We’re aware that the angles on the seam allowances aren’t working properly and there is an issue registered on Github. @Douglas is just busy with other issues and will do a complete overhaul of the seam allowances once he’s done.
Some angles. :slight_smile:
@krumplib430
What Grace said. :slight_smile:
