Can this Design and measurement files go past size 14?
I really wanna buy this but I’m like minimum size 16 in the Aldrich pattern making book
Screenshot 2024-03-23 091912
You can change the size range covered in the Pattern Preferences and I’ll send you the next size range measurement chart according to the book. Send me a PM when you have the pattern, I’m going to create the next size range chart :smiley:
May I ask, is this also the pattern drafted file so it is possible to change it? And was also larger sizes added? (I am also larger than 14).
Yes, you can take your personal measurements for the areas used in the pattern and load an Individual measurement file into the pattern (Menu > Measurements > Load Individual (or Multisize)).
This is what I love about using Seamly. As long as all of the measurement areas are in a measurement file and the pattern caters for a large size range, you can very easily switch measurement files in the pattern and also go back to the original size chart, if you wish.
