Can't see my pieces
Ive gone in a created my drafts and then created them as pattern pieces. Its only 5 pieces in total and they are basically rectangles or squares as its for a bag and the pieces are on the fold. However. Now I go into the pieces vie and I can’t see them. I selected View all and I can only find them when the zoom at 1.3% … Um!!! !!
Just check that you created the pattern using CM & not MM and that you entered the correct measurements accordingly… :grin:
It sound to me as though you used mm when you created the pattern file and have been entering cm which are being interpretted as mm, and so your pattern is now 100th of the size you actually want.
