Is it possible to change the line colour for some lines in draw mode? I can see there is a property in the file - lineColor=“black” - but I can’t see any way of changing it through the interface.
Hello redshoes,
yes, there is. On the right side, in the tool-box (if it isn’t there got to menu Pattern Piece and check Tool Box) comes something like “line color” if you click on a point. It also comes in the pop-up-window when you created a point with a tool. Per default it is black; if you click on the pull-down-menu where black stands in you can choose between a couple of colors.
Thank you! I think I got confused as it doesn’t automatically consider all line segments to be separate lines unless you draw them specifically. Makes sense now though.
