he tratado de importar las medidas de una muneca barbie y estan en archivo vit pero no encuentro el boton de importar ni se como hacerlo pueden ayudarme con ese tema
You don’t need to import it, just open the file with SeamlyME. It should open just fine. Then you can Save as .smim.
me podrias dar un paso a paso porque no se como poner el archivo .vit en seamly me
That’s assuming the vit was made in Tape with schema ver 0.3.3 or earlier.
Fortunately the Tape schema skips from 0.3.3 to 0.4.0, while the current ME is 0.3.4 so we can’t have a conflict with two different 0.3.4 schemas.
I wouldn’t mind a copy of that file myself. Post it here, & I’ll have a look & get it turned into a modern .smis for you & tell you how I did it for any future incidents. On the 26° probably.
