I created a pattern in Valentina, which I can’t open in Seamly because of a versioning mismatch. I’m now updating the meta data using Notepad++, but I’m stuck, because I can’t identify everything, how to rename it. Does anyone have a mapping file? like Valentina draw = Seamly draftBlock, Valentina typeLine = Seamly lineType, etc. Currently I’m stuck at firstToCountour and lastToCountour.
If the Val pattern is version 0.6.3 or before you can still load it into Seamly. After that you’re not going to have much luck as there’s changes other than just the name. For ex: the “passmarks” in val are converted and implemented totally different as Seamly “notches”. That is, not only is the tag changed, so are the attributes. Also there may be features in Val that are not implemented in Seamly.
