Crazy Question about changing multi size ranges with 1 pattern
I’m just about to start working with Seamly2d and would to understand if use 1 set multi sizes (Young Women ) from Winifred Aldridge to create a pattern, would I then have to do the whole process of creating a the same pattern again if I wanted to use another set of sizes ( mature women) from Winifred Aldridge. Or could I just copy the pattern created and select another size range? Basically 1 pattern in 2 different multi size ranges? Many thanks Mark
Yes. You only need to draft one pattern file - the size(s) is(are) determied by the measurement file used. Keep in mind that a given pattern may not work over a large ranges of sizes.
Hi Douglas, Thanks for your help with this… I bear your advice when working on the patterns, but if this works it will save a lot of time in creating the same pattern in different size ranges. Many thanks again. Mark
