Critical error: file exception
Hi there! I just started working in Seamly a while ago, and I’m running into a critical error where the element draftBlock isnt defined. The error message says: “Exception: Element draftBlock is not defined in this scope. Validation error file [file name] in line 3 column 30.”
I’ve opened the file in notepad (I didn’t edit anything, just wanted to see what was going on) and there doesn’t seem to be a blatant issue I can spot. I’d love to know if someone knows how to fix this error, the pattern I made isnt that complicated but it would still save me quite some work.
This is the file: dino 5.sm2d (18.9 KB)
Thanks for your help, Ava
The order of the XML file got mixed up… which is important. A pattern is parsed in a particular order, and the fact the order was mixed up it’s throwing an exception.
I fixed the file… but note I had to remove the reference to the measurement file that was not used anywhere in the pattern file. In the future if a pattern uses measurements from a file, we need both files to be able to open the pattern. You can create a measurement file from a pattern, but all the values are zero, so you have to guess what they are.
I tried this, and this is why I know there were no measurements used, as the import was empty.
dino 5_fixed.sm2d (18.8 KB)
Thank you so much! I knew I hadn’t referenced the measurements file yet so I didnt think it was important, good to know it was fixable without the file. I think the issue started when I tried to add another pattern piece detail and the program failed to load it, but I’m not quite sure how that would have messed up the order of the XML file. Regardless, thanks for helping!
Hi, just had the same critical error on my file. Before starting my project, I created the measurements file I was going to need. Then I opened Seamly2D. I referenced my measurements file, started the pattern, then saved it. When I want to open it again the same error appears. Only difference is that it’s row 3 column 41.
I put right here the two files, measurements and pattern. If you could help me as you helped Ava, it would be wonderful!!! Ride-astride-coad.sm2d (7,3 Ko)
And here is the measurement file used Johanie.smis (1,7 Ko)
Here’s the fixed file. I’m not sure what’s causing the header part of the file to be written at the end. :thinking:
Ride-astride-coad_fixed.sm2d (7.4 KB)
This part:
Needs to be up here: image
Thank you so much, I try it and give you news soon!!
Just FYI - I have just experience the same problem - but your instructions to move the header to the top of the file worked.
