Critical Error - Measurement file doesn’t include all the required measurements
“Critical Error
Exception : Measurement file doesn’t include all the required measurements
Please provide additional measurements
@Across_Shoulder_Half”
Ölçü Modifiye Ettikten Sonra Error
While drawing the T-Shirt pattern I modified the measurement file;
Calculate quarter of the shoulder value “Across Shoulder Value Half” then rename It as Across Shoulder Quarter.
Save and closed the measurement file.
When I returned to the file.
I got this error.
Now I can not load the measurement file I created?
How can I fix It?
How can I prevent the error from happening? TShirt.smis (1.3 KB) T-Shirt.sm2d (2.7 KB)
Rename the measurement back OR add “@Across_Shoulder_Half” in SeamlyMe. The easy way to add missing measurements is to load the measurement file into SeamlyMe, then Import the missing measurements from the pattern:
of course you then have to give them a value.
Don’t rename measurements once you have used them in a formula - without renaming the measurements in every formula that uses it.
Here’s the files back with the groups issue also fixed. You have to add a real value for the imported measurents as I just guessed at a value so the pattern wpuld work.
T-Shirt_fixed.sm2d (2.6 KB) TShirt_fixed.smis (1.4 KB)
Thank you very much for the answer.
