Hello,
I have a document that does not want to open when I worked very well on it.
Can you get it back?mesures_femmes.vst (2.4 KB)Bombers.val (40.3 KB)
Hello,
Hello lilou,
I think you will find that if you add @longueurtailledevant, @tourdetaille, @tourdubassin, @longueurdepaule, @hauteurdebassin and @carruredevant into your Measurements Table (mesures_femmes.vst) you should be able to open your Pattern drawing again. It worked when I tried it just now.
mesures_femmes.vst (3.0 KB)
Good luck, and I’m sorry that I cannot respond in French.
hello
Thank yoou for helping but I think I gave you a wrong measurements Table.
Here they are the screen shot of the problème. I am not able to correct it
I have removed the parts that were causing the error, so you will need to recreate them. When using the Union tool, please copy your work into a separate file first as security because the slightest thing can cause this type of problem.
Here is your corrected file
Bombers1.val (36.8 KB)
wonderfull !!
Thanks a lot
