Default pattern piece on program open
Is there a way to specify the default pattern piece to display when the program opens? I know it is very easy to switch among pieces by just clicking the desired piece from the drop down menu, but I have a use case where I need Seamly2D to open on the default piece.
Normally, the pattern layers are displayed in alpha numeric order, so if you name them 1 Sleeve, 2 Bodice Front, 3 Bodice Back, etc. the default will be 1 Sleeve, followed by 2 Bodice Front, etc. etc.
Ah, thank you. It seemed to not work by alphameric but it does work numeric so adding 1,2,3 before the pattern pieces works. Thank you!
