Hello developers I’m using seamly for nearly a year now and what I noticed is that when we export the files in dfx format into any other vector software there is a discrepancy in the measurements. This does not happen in svg or pdf format only in dfx. I just wanted to bring this glitch in the software to your notice. Thank you
What DXF export format have you tried? There’s like a dozen choices between flat and AAMA.
And have you checked your line settings in the software? Normally one can choose between having the line on the outer, centre & inner part of the stroke.
