Digitalizar patrones fisicos
Hello! Good morning
I’m a newbie and I’m just learning how to use Seamly2D.
I have patterns that I made on paper and I would like to digitize them and grade them to have more order.
Is there a way to do this using Seamly2D?
Thanks in advance everyone <3
Hola! Buenos dias
Soy novata y recien estoy aprendiendo a usar Seamly2D
Tengo patrones que hice en papel y quisiera digitalizarlos y graduarlos para tener mas orden.
Hay manera de hacer esto utilizando Seamly2D?
Gracias anticipadas a todos <3
Hola! Bienvenida a Seamly!
Si, puedes, mas o menos. You have to re-draft it into Seamly2D. Once that’s done properly, it’s a cinch to re-size it however you need, even non-gradable sizes. Thus you can pleasantly eliminate all but one fitting session, & even that one should be more of a formality.
I did come up with a way to enter existing patterns of a known size… which is not drafting using a given pattern system per se, but rather locating the grade points of the pattern pieces. I outlined how I did it with this pattern…
