So I was making a shirts, after everything is done, I add the seam allowances. Everything going on well except for the hemline on the front shirts. It is distorted. It seems I traced the order of nodes wrong but I re-check and it doesn’t seem to be it? What do I do wrong?
The order should be hemfront5-hemfront3-hemfront-hemfront4.
Checke the nodes in the tab “Seam allowance” of the window you show. You seem to have messed up there. You probably wanted to have something like 1 cm before hemfront5, 2 cm after hemfront5, then 2 cm before and after hemfront 3, hemfront and hemfront 4 and 2 cm before to 1 cm after hemcurvef. I suspect that you have something about 1 before and after hemfront4 and/or hemfront, then something about 0 after hemfront 3 but 2 before hemfront3.
I’ve checked multiple times but I think I didn’t make a mistake there. I tried to re-trace the pattern but the problem still persist. Here is the nodes details:
Yes, as @moniaqua said I want the hemline to look like what she posted… The problem is, my other pattern pieces are working fine, but only this one has trouble. I’ve attached the files below:
Ok, I think I found it. I traced the front again. hemfront4 does not seem to be part of the spline, it seems to be just a little bit underneath. If I leave it out, the seam works:
Funny thing: the seam in your detail looks quite ok when it is only default. I still suspect it does something wrong; if I include it I get some funny detail-outline going down to hemfront2. I think if you need hemfront4 you need to make a point there with intersection of axis and spline.
The passmark is showing but over the internal line. I changed it to a V passmark & saw it:
It did this because, although you included the node, it wasn’t attached to the curve used. I put a new node onto the curve and included it (and excluded the F11 node). It’s now working perfectly:
