Hi all, I’m new to using Seamly2D, let alone any type of CAD software for fashion design. I have absolutely no experience whatsoever. I am in the process of watching tutorials for Seamly2D and SeamlyMe.
My question is, does one need to have previous knowledge using a CAD program before learning how to use Seamly2D? I am completely lost haha
No, but it helps. While Seamly2D is a CAD program of sorts it differs from the typical CAD program in that it is ‘parametric’ and everything has a formula. The formulas allow you to make one pattern draft and automatically resize it with the change of a measurment file. For ex: Instead of hardcoding a formula to the bust measurement - which you can do if you want - we use a measurement variable named bust_circ. When you load a measurement file into a pattern the variable ‘bust_circ’ is replaced by the person’s measured bust. Change the measurement file to another person with a different bust measurement and the pattern automatically resizes using the new bust measurement.
Might I suggest to try following the tutorial in the WIKI.
I don’t think you need to have experience with CAD. I have a lot of experience with it, but it sometimes makes me impetuous because professional CAD programs are much more complex and offer many more options. Seamly2d is nice and very manageable software.
An engineering approach to pattern making helps. By that, I mean:
You need to understand how a 2D plan transforms into a 3D object.
Joy to work with measurements and formulas rather than just by sight. “Adding a little bit” doesn’t work in parametric software.
All of that can be learned; you don’t need to already know it.
That’s because ‘normal’ CAD or Vector programs are generic where Seamly2D / Me has a specific function - that is drafting garments not airplanes or buildings or whatever. Many of those other ‘options’ are meaningless in how Seamly functions and the way garments are drafted. Probably the closest type of ‘engineering’ CAD drawings to garment patterns would be furnace duct work.
Well that’s a given with any type of flat drawings and visualizing how it looks in 3D or vice versa. Can’t count how many years of isometric draftings I did in drafting classes.
BTW… my 1st degree was in Civil Engineering… we had no CAD when I started drafting,
And after 40+ years in the costume business I can say you never stop learning how to make flat pieces of fabric fit the body. You may learn how to draft a mens jacket for a normal sized person and then get thrown a curve of having to deal with a 6’=6" giant or a tiny boy or even a 250lb Rosie for Mamma Mia!.
Exactly. And as you alluded to in some cases it may be easier without knowing CAD, because you don’t have to unlearn habits.
Thank you for your guidance. I am more hands on when learning something new. So the video tutorials and the start to finish Seamly user manual will help greatly when I dive in making a first pattern. The program looks intimating for me as I have only drafted 2D patterns. I design costumes and latex clothing. I primarily want to learn Seamly2D/ ME to start making computer drafted patterns. I got a 3D bodyscan now too which will help immensely. Using a store bought dress form for a fitting doesn’t work when the garment is form fitting and the pattern has to be customized to fit every individuals body measurements.
I use to co-own a costume shop for 40+ years until a tragic fire destroyed the building we were in. That said… I got tired of drafting / grading patterns everytime I needed a pattern and that’s where Seamly came into play. Once a pattern is drafted in Seamly all I needed was an actor’s measurements and I could plot out a “made to size” pattern.
One of my employees use to make custom dress forms of his niece and nephew that he used to make them Halloween costumes.
That said… again this is where Seamly is useful where the size can be customized to an individual. BTW… most dress forms are all built with ease in them. Because Seamly is parametric you can easily draft a pattern and formulize how much ease you want in a pattern. You can also take into account a stretch factor for materials like lycra, where the pattern is actually smaller than the individual, but designed to stretch. Think of it as a negative ease.
Right that how latex patterns work along with the seam allowance, which is not the same as a sewing seam allowance. .
