Duplicate pattern piece
Hi all, Im a newbie to pattern drafting, and the pattern systen i use to draft has seperate front piece and the back piece can be created by making adjustment to certain elements inthe front piece. So can i duplicate the front piece in the same pattern file? Thanks in advance
Like Copy/Paste? Unfortunately no. However, with the Point - On line tool it is easy to add in additional points in line with your existing draft. As an example of drafting front & back together, here’s a poorly drafted tunic pattern which I made a while ago: Tunic.val (24.3 KB)
ETA: A measurement file for the pattern: tunic.vit (961 Bytes)
Oh ok. Thank you :blush:
