I have an issue that i can’t fix. When i am switching from Details mode to Layout mode, my patterns are melt (superposition) on the same sheet. Do you have an idea where does the problem come from ? Thanks =)
J’ai un problème que je n’arrive pas à régler. Lorsque que je passe du mode isolation au mode plan de coupe, mes patrons sont mélangés (superposition) sur la même feuille. Avez-vous une idée d’où proviendrai le problème ? Merci
Oh, wow! no, I’ve never seen anything like this. Can you let us know which version of Seamly2D you’re working with, details about your computer - whether 32 or 64 bit, Windows, etc. - and post a sample of the pattern (.val and .vit files) that you are working on so that the programmers can try to recreate the problem to find where it is coming from, please? If you don’t wish to post your pattern files here, you may send them in a personal message to @Sue or @kmf. I’m not a programmer so I’ll only be able to check your pattern on my Windows 10 system.
Yes please take a screenshot of the Lauput dialog box.
I’d like to know the options you selected so I can try to replicate with other patterns in addition to yours.
