Correct… because the file was written incorrectly with the previous ver. The new release will only write patterns correctly, it can’t read an incorrect pattern file. I fixed the pattern in the other topic, but here it is again:
I also encountered the bug. Seamly crashed 3 times while I was trying to make a very simple file. I recreated it twice and the answer is not obvious to me even with a text editor. Could you fix this so I can open it pretty please. It has no associated measurement file. I used custom variables. In case it is a new bug, I had just deleted the last element of a group and it crashed when I tried to delete the group. I now have the latest version of seamly2d. (Built on September 14 2:07:12)
The bug was an unintemded oversight when the image import was added in that when the draft block section was created it was not implicitly writing out out the full schema of element tags - evenl if they are empty - which led to sometimes the <images> getting written before <groups>. Because the pattern XML is validated against the schema the order has to match. The excception “Element groups is not defined in this scope” is computerese for the ‘groups’ element is out of order with the ‘images’ element. "
