files created about a month ago. An error message appears which I attach:
Initially I thought it was because I’m switching from a Mac to Windows computer but when I try on the Mac too the error is the same.
But I also ask you: is it possible to open files created on Windows on a Mac computer? Thank you
You are trying to open a pattern that is newer than the version of the application you’re using. You need to update the app to the current release which writes the 0.6.9 pattern version.
OR… you might find the file as a backup file saved as the previous version before the file was converted to the new version.
Like: I can tell this file was orginally saved as ver063 and I’ve opened it 16 times with a newer version of the app.
Basic Blouse with New Resizable Sleeve - Bev - B_v063_(15).val
It’s a safety feature in case a user has to revert back to a previous ver of the app. It’s also a good reason to keep the backups for awhile until you know there’s no issue with a newer app release.
OR
If you know you have not used the features contained in the new version, you can simply edit the ver number in the xml file to the previous ver.
<pattern>
<!--Pattern created with Seamly2D v0.6.0.1 (https://seamly.net).-->
<version>0.6.3</version>
You can edit a pattern xml file with any text editor. I would first check though if there are any backup files before trying to change the pattern ver. Or better yet… just update the app.
