I am unable to open this file using either an older version (Valentina) or the very latest version of Seamly2D. It is my only file, and I don’t have a backup.
May I send the file to you?
Thank you for any help you can provide.
Caroline
Yes you may. Include amy measurement file you may have used. If it’s an older val ver prior to the fork we should be able to recover most if not all the file. If it’s a val file created in Valentina after the fork it becomes iffy what parts can be saved as a Seamly file.
The problem wasn’t with opening the files in Seamly, it was with the naming of some of the points. A while back, we had to change the use of comma’s and points in the names because this interferred with the formulas. I had to go in with a text editor and manually change 2 labels names replacing the commas with an underline.
Now your pattern loads into the latest Seamly perfectly and I’ve saved them as Seamly files. Here they are back:
