Error openning file
Hello,
trying open a file saved yesterday I have this issue :
Exception de fichier.
Exception : element ‘groups’ is not allowed for content model ‘(calculation+,modeling+,pieces+,groups?,images?)’
What I need to check please ?
Pascal
Chemise_CM_V1.sm2d (47,5 Ko)
Nelly.smis (6,8 Ko)
Here are the files
Hello, @Pasque
Sorry I’m only seeing this now. I’ve just come in from the office.
Here’s your repaired pattern back:
Chemise_CM_V2.sm2d (47.9 KB)
Drawing board 1 had the images before the groups. Drawing board 2 & 3 were correct.
Thank you for your help, I don’t understand how this arrives… I just use the software without modify the files.
It’s probably because you are using a version that had a bug in writing the <groups> and <images> tags out order in the pattern file. I would suggest you to update the software but don’t do it until next week when there should be fix for another bug.
