Error parsing file : help please
Hi everyone,
When I try to open my pattern and i see this message "Error parsing file.
ExceptionObjectError: Error creating or updating piece". I can’t change anything or fix the problem unfortunately. I think the problem is that I deleted the point crandessuscol in the pattern piece. I really hope someone could help reopen the file that’s so frustrating. Thank you so much. Roberoma2.sm2d (151,8 Ko)
Here is the file and the measurements used. measurements.smms (3,8 Ko)
Yes… that was the source of the issue. It’s a bug I’m currently working on fixing.
Here’s the pattern fixed. I did not save with the current release as the pattern version with what ever build release you’re currently using has been bumped. You may want to update the app when you get a chance.
Roberoma2_fixed.sm2d (151.8 KB)
Thank you so much for your help, I can’t believe the problem is fixed! Thank you so much you’ve brightened my day !
