Hi, I was getting error formula error and I can’t open my pattern. If I clicked fix formula, it leads to my tape but the tape is blank.
It started when I tried to change the value of my measurements, so I clicked edit current measurement but the tape wasn’t opened. Then I manually open my measurements, edited and saved it. After that there was a notification that the measurements was changed and it would be sync. Suddenly I was getting that error and it closed suddenly. What’s wrong? Please help. I’ve attached my pattern and measurements.
No. It’s showing you the Variable Table… which is blank because (somehow) the pattern lost the reference to the measurement (.vit) file.
Anytime you manually edit the XML files directly you run the risk of mucking things up… always make a backup before attempting to edit a .val or .vit file.
