File exception error. How can I fix it?
Hi,
New to Seamly and really enjoying it. But my file is no longer opening. I think the problem is related to the measurements file because patterns using a different measurement file aren’t getting the error message.
This is the message:
File exception.
Exception: Premature end of document.
Parsing error file in line 1 column 1
Any idea how I can get back into my file?
Thanks a lot
Hi Kiah,
Can you provide us your pattern file and both measurement files so we can take a look? Also if you haven’t already done so I suggest you update to the lastest release.
Updating to the latest release seems to have worked! I’ll reply if it happens again. Thanks so much for such a quick reply.
