Fill color in layout
Hello,
I’d like to use the fill mode in the detail view adding colors and some dots and lines inside my patterns using this parameter. But when I go to the layout mode all my pieces are plain white. Is it normal ? Do I have something to activate ?
Thank you !
This currently only applies to piece in Piece mode.
Is it planned to applies it in layout mode ? It’d so useful to differentiate external fabric, lining, etc..
The layout mode is for printing / plotting / cutting… so you’re not going to want to use a color fill. Plotters or cutters don’t do fills anyway.
However… you can use the color pref for grainlines, notches, labels, and the various paths:
If you want to add color to internal lines yu can set the Internals pen attributes.
And while I have a symbols feature in the works (dots, squares, arrow, etc) you can create small circles in draft mode around a point and add them as an internal path. Of course they are going to be what ever Internals color you set.
It’d in deed be useful for me to ease cutting. Each color or filling attributed to lining or main fabric. It’d avoid mixing up pieces As I video project my pieces and not print them, the definition doesn’t always allow me to read the labels correctly. A more visual aspect would be appreciated. is that something you could implement or not at all ? Is that complicated to do ?
When you create a layout or export pattern pieces you can select which pieces to include by clicking the “eye”. That way you create a layout or export the fabric pieces separate from the lining pieces.
If you are projecting your pieces you may find Exporting from piece mode better anyways as you can some what create a better layout than the Layout mode will. And in that case you can color the pieces according to fabric or lining.
I’m not sure how a fill would help with the labels?
And just a note… in the layout print settings… Uncheck the Export text as paths or the text will show as an outline vs solid:
And I’m not sure what a more visual aspect would entail?
Speaking of that, would it be feasible to implement Hershey fonts for exports? It would cut plotting time by a fair bit.
