Whenever I use the “Move Object” function, the software crashes. It happens every time: after I select the objects, configure the settings, and fill in all the options, the system shuts down immediately upon clicking “OK.” I have tried this at least 20 times; only twice did it save successfully without an error. In all other instances, the program simply exited, and the “Move Object” operations were not saved by the system.
