Formula button error crash
  • Open seamly2d and downloaded fine on new MacOS monterey
  • Error happens when i try to hit the formula button on a line length after loading my individual measurements. Instant crash.
This is the crash report (just the summary bit because the whole thing is huge):
Application Specific Information: *** Terminating app due to uncaught exception ‘NSGenericException’, reason: ‘-[NSApplication runModalSession:] may not be invoked inside of transaction begin/commit pair, or inside of transaction commit (usually this means it was invoked inside of a view’s -drawRect: method.)’ terminating with uncaught exception of type NSException abort() called
unallocated: VM_ALLOCATE (reserved) MALLOC_MEDIUM (reserved)
MALLOC_NANO (reserved)
Hello, @sjd, and welcome to the Seamly2D forum.
This error seems to be the same as one that was posted a few days ago. @Sue posted a solution that may help you. You will find it here: Formula assistant crashes program - #8 by slspencer
Please try this fix and let me know if it works for you. If it doesn’t, we’ll need to get someone to help you further.
Thank you.
